  1. What type of file is a mp42 and how can I convert it to play on a SCVD? Whenever I try to open it to TMPGEnc, it says "cannot open, file not supported". What can I do to fix this? Thanks
  2. Member spidey's Avatar
    Apr 2001
    U.S.A.
    You need the MS Media Player v 6.4 fix. In the player by default the M$ code is wrong for Mpeg layer 4 avi files. The old Mpeg4 codec (not DivX, but another) can not play in the media player in it's original config, hence TMPG can't open the file as the necessary codecs aren't there.
    Did a quick search and found them. Page link:
    http://www.xxxmoviemart.com/faq/extfaq/codecs.html
    Win 9x http://www.xxxmoviemart.com/faq/extfaq/codecs/mpeg4x.zip
    Win NT Win2k
    It's from an adult site's FAQ's. Sorry, all the search found. Hope this helps....
    ~~~Spidey~~~
    "Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards
  3. That did the trick, thanks a bunch!!!
