    Jul 2005
    Connecticut
    I've got these folders. CD1/CD2/CD3. and inside each one theres a whole bunch of .RAR files and .R00-.R24 (etc) then an .sfv file. I've been reading for a few hours now, and I see some options. Is there a way or a program that can rip from these RAR files straight to DVD? or do i have to go through thirtyteen million steps to extract, mount, decode, encode and burn onto the DVD. i bought SVCD2DVD, i also have DVDshrink and Nero. Any ideas?? they would be greatly appreciated. thanks.
    I've also got VLC player and when it plays the movie, at the beginning and end of each snipped video (its split into like 24-25 parts in each CD), it skips and has some pieces missing. Will this affect the final product? im just dipping my feet in the pool on this, but im a quick learner. any help would be appreciated once again. Thanks
  2. Member lumis's Avatar
    Jan 2005
    the remnants of pangea
    i think you're making things a bit too complicated for yourself.
    1) extract cue/bin from rar's with winrar
    2) mount cue/bin with daemon tools
    3) use svcd2dvd and navigate to the mpg file on the virtual drive(s)
    you're not going to get around extracting files from the rar's.
    Jul 2005
    Connecticut
    for some reason, mounting didnt work, so i just used SVCD2DVD the whole way after extracting. When I tried to mount then navigate and throw it in the assets. Its like it didnt even work. So I just straight up extracted it and now its led me to i think my final problem, but i should be fine, thanks lumis
