I understand the process of going from SVCD to DVD, the problem I have though is I have the files on 3 seperate disks. Can someone help me out and tell me how I can recombine these 3 disks to one file so that I can reauthor everything?
you can use different files, just set the avg bitrate correctly for the time on each disc.. once they're dvd mpeg's, pretty much any program will accept them.
I use ISO Buster to rip the mpg's from the disks, then author them in DVDLab.
No re-encoding needed.Cheers, Jim
My DVDLab Guides
Combining DVD's
By grandsire02 in forum Authoring (DVD)Replies: 2Last Post: 8th Apr 2012, 07:06 -
Combining DVD ISOs
By TheLaserdisc in forum Authoring (DVD)Replies: 0Last Post: 19th Jul 2011, 21:39 -
Backing up to Hard Disks-Not using Disks any longer.
By cal_tony in forum DVD RippingReplies: 5Last Post: 31st Dec 2009, 12:40 -
Combining 2 DVD's help
By rede96 in forum Newbie / General discussionsReplies: 2Last Post: 30th Nov 2009, 14:35 -
Cost of disks, blue ray or HD DVD, for data storage? Any good disks?
By overloaded_ide in forum MediaReplies: 16Last Post: 9th Nov 2007, 10:24
