Hello,
Does anyone know of any music cataloging software that can be used to catalog music manually? I have a lot of vinyl I am transferring to my hard drive and then burn them to DVDs for storage. The problem is that many of these Vinyl are from artists that were not popular in America and in many case are not even known here, so getting information about these artists and albums on the internet is almost impossible..I just need a database software that can list them ( I know I will Have to type in the info Manually)
Thanking you in Anticipation
You might Music Collector at - http://www.collectorz.com/?v=1218240. Says you can manually enter LP info as well. Haven't tried it myself. However, I use their software for my video collection which allows a lot of manual entry for VHS tapes, laserdiscs, etc. and lots of flexibility in the reports that can be generated. They give you a free trial, although it is probablly limited by the number of entries (for video, it was 50). If you really want to go manual, you can always create your own with something life MS Access. Hope this helps.
wwaag -
Hello,Originally Posted by wwaag
Thanks very much for the info, I downloaded the program through the link, and I must say, this will work well for me.
Thanks again.for your help
thepunchman
best software for recording band music
By d_unbeliever in forum AudioReplies: 9Last Post: 19th Jun 2012, 02:27 -
software to mute the singer's lyrics but keep the music?
By jbitakis in forum AudioReplies: 13Last Post: 17th Jun 2012, 11:59 -
music enhancing software
By deadrats in forum AudioReplies: 2Last Post: 25th Jun 2011, 21:06 -
How To Catalog DVD Files on your Harddrive(s) - Best Software? vts,ifo,bup
By RandomAnalizer in forum Newbie / General discussionsReplies: 5Last Post: 13th Mar 2011, 22:16 -
htpc play music video software
By scorpio1959 in forum Software PlayingReplies: 2Last Post: 5th Jul 2009, 07:00
