Results 1 to 13 of 13
  1. hi, i'm trying to add subtitles to a DVD4 movie that i have on my hardrive. it is in a VIDEO_TS folder with these files in it:
    how do i do this with ffmpegx without touching the video/audio quality?
    -fission
  2. You can't add subtitles with ffmpegX without reencoding the movie again.
    May 2005
    Philadelphia
    is there any way to add subtitles, with anyother app? I want to add 2 .srt files to a dvd, that has no subtitles at all.
  4. Try with DVD Studio Pro, but it does not support SRT.
    May 2005
    Philadelphia
    well than is there a way to convert an .srt to something DVD Studio Pro will take?
    May 2005
    Philadelphia
    major do I have any opitions?
  7. I don't know of any, apart from copying/pasting the titles one by one to DVD Studio Pro. I could add in the future a tool to do the conversion (ffmpegX has a tool for converting SRT to DVDSP 1.5 but the format has changed in later versions of DVDSP).
    Jul 2005
    Finland
    You can try TitleLab for converting .srt -> DVDSP.
  9. Unless I'm wrong, TitleLab is also using the format for DVDSP 1.5.
    May 2005
    Philadelphia
    cool thanks all
    May 2005
    Philadelphia
    so are there any guides on copying/pasting the titles one by one to DVD Studio Pro? I have never used DSP
  12. You just click the subtitle timeline and a cursor appears in the preview, and there you can paste any text.
    Aug 2005
    Croatia
    Have you tried Subtitler to convert SRT to STL ?
    check it out here:
    http://www.versiontracker.com/dyn/moreinfo/macosx/26322
