Hi
can somebody clarify for me whether it is necessary to input a value for "min keep in"? I can't find an explantion of this in the online manual.
You may enter there the movie duration in minutes, eg. 68 minutes. If you also enter a target media size in the MB field, eg. 700 MB, and click "Rate", you will obtain the bitrate allowing to keep 68 minutes of movie within a 700 MB media. The "Auto" button will also adjust the image size.
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 07:38 -
Question about bitrate, spikes and Bitrate viewer
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 25th Oct 2010, 15:01 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
Most compatible codec, Lossless bitrate, and max bitrate
By sevenlayercookie in forum Video ConversionReplies: 2Last Post: 6th May 2009, 20:43 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 7th Nov 2008, 23:54
