AFAIK I have never had problems with S2D making chapters every 5 min, it has been set that way in the default optins forever.
Here's what I did:
Got an ISO of a movie which had no chapters. Otherwise it played fine with
Power DVD-5. Mounted the ISO with Alcohol 120%, pointed VOB2MPG at it and extracted a 3GB+ MPG. Ran that thru current S2D and
played the VIDEO_TS file with PDVD, as is my wont.
PVDV says it still has only 1 chapter.
Bug or something I did wrong ?
TIA, P-PA
Well that clearly is not right. If it is only that run then a sample uploaded to my ftp would allow me to investigate. It would need to be at least 5 mins worth.
look @ tools\makesample.exe in the SVCD2DVD folder. I do need a sample from the original mpg without any further programs influence...
Also the ftp server will not be available till sunday i'm afraid...
Here's the current state of affairs with this movie.
Before I got your reply about MAKESAMPLE.EXE I did a 6 min cut of the beginning with Womble, then ran that MPG thru S2D. It added a chapter fine. Womble fixes so many things, I love it !
Thus I believe that I can get studly results by processing with Womble, and am doing that right now, I also took the opportuniy to cut out some
junk [balck screens] from near the start and at the end - about 30+ seconds.
Bottom line is that the problem is with some anonymous poster's gorked
DVD, if you want a sample for technical curiosity or whatever I will up it
via yousendit.com - a great site, anyone can upload a file up to
1GB, they send the uploader and his pal an email with a link to d/l it with his browser, and it lives on their server for 7 days, and it's all FREE !
So, if your FTP is unavailable but your browser works you will have it as soon as you care to snag it - you'll get an email when I have up'd it.
Cheers, P-PA
Advice needed for 1st time HTPC
By hanugro in forum Media Center PC / MediaCentersReplies: 19Last Post: 17th Mar 2012, 13:07 -
1st time LCD TV buyer
By majax79 in forum DVB / IPTVReplies: 60Last Post: 12th Dec 2009, 18:18 -
1st time HTPC - No drives in the case.
By Bronx in forum Media Center PC / MediaCentersReplies: 10Last Post: 15th Sep 2008, 13:27 -
Panasonic DMR-E55-E55S or E55K?1st DVD recorder/1st time posting
By ToeTagged in forum DVD & Blu-ray RecordersReplies: 7Last Post: 19th Jan 2008, 15:33 -
1st time on linux: looking to convert my DVDs to x264
By bgbop15 in forum LinuxReplies: 3Last Post: 19th Jul 2007, 14:56
