Does anyone know of a way to import animated text (similar to web design using animated GIF files) into MENU screens.
I would like to achieve the word PLAY in a flickering flame effect. Can this be done using DVDLAB pro? I cannot import GIF files into menu screen.
Any help.
Thanks.
You can make an animated background in an NLE (Premiere, Vegas, etc) and use it as your menu background or combine any number of static or animated elements in your NLE to be your background. Then I believe in DVDLab Pro you can make an invisible button and place it over your animation to select your next menu or movie. Your final background needs to be mpeg2.
Mark -
You can use the built in D-FX to make a flaming PLAY word (or anything else).
Cheers, Jim
My DVDLab Guides -
That's excellent! Many thanks for your help.
I am on the case now.
Thanks again.
DVDLab Pro ugly text
By optikon2222 in forum Authoring (DVD)Replies: 1Last Post: 14th Oct 2010, 15:26 -
DVDlab Pro: Text set as visible isnīt visible in the result
By Alex89 in forum Authoring (DVD)Replies: 14Last Post: 12th Aug 2010, 08:09 -
DVDLab Pro Menu Text Disappearing
By C0SM0 in forum Authoring (DVD)Replies: 3Last Post: 20th Jan 2009, 17:33 -
Animated Text Sound FX Needed
By drtalk in forum Newbie / General discussionsReplies: 8Last Post: 8th Jun 2008, 22:24 -
Animated thumbnails Magix Movie Edit Pro
By gayclarke in forum Newbie / General discussionsReplies: 0Last Post: 14th Aug 2007, 09:21
