i've got XP on my 2 HD's.
one of them is playing up, so i disconnected it, set other to master.
started PC and get CLIENT MAC ADDR: 002 B395 etc
invalid partition table etc.
googled it was recommened to disable "boot other devices" in dos and also disabled LAN boot thing.
got same error or another one.![]()
i suppose i could just disconnect bad one and set newer one to master stick in XP CD and start again, but is there another way?
If it's FAT32, boot to a floppy, and change to C:, then type a:\fdisk /mbr
Run fdisk, and set the first partition active.
It should then boot.
If it's NTFS, boot to the XP CD, and do an over-the-top repair install, or use the repair console if you know what commands to use.Cheers, Jim
My DVDLab Guides
need help with something simple
By HandsomePete in forum DVD RippingReplies: 6Last Post: 4th Dec 2011, 02:40 -
Simple task, not so simple (rip/quicksync)
By Trife in forum Newbie / General discussionsReplies: 10Last Post: 12th Aug 2011, 19:57 -
Adding extra material to the end of a simple 1 movie dvd (with simple menu)
By ColinKe in forum Authoring (DVD)Replies: 4Last Post: 24th Jul 2009, 22:38 -
Can we keep it simple?
By AlSat in forum DVD RippingReplies: 14Last Post: 26th Jan 2009, 14:46 -
Creating simple "movies" with simple graphics?
By uniks in forum Newbie / General discussionsReplies: 11Last Post: 24th Mar 2008, 01:25
