    Jun 2005
    Northern Calif
    Does anyone know of a good 3d text animation software package that is good for creating intro's for movies? I saw that Ulead has a product. I'm hoping there might be something very affordable that does a good job.
    Thank you!
    Feb 2004
    Australia
    Try Blender , its great for simple projects , to extremely complex 3d animation , can also be used to develope games .
    You can recreat animations similar to those as used by pixar .
    However , should you want to go this far , grab all the tutorials from their site to get started with .
    You can also create games with it .
  3. I have used bluftitler as well, it does what you are asking.
    Jun 2005
    Northern Calif
    When I tryed installing Bluftitler it didn't work. Received an error msg stating that it's not a Windows based application
  5. you don't have your video card in your computer specs, but I do know that it uses Directx, maybe your card doesn't support the required version. Other than that...don't know (could be any number of reasons). Works fine for me on both machines I installed it on.
    Jun 2005
    Northern Calif
    Mike,
    You're right it worked the last time, except I don't have the video card that is needed. I'm thinking about buying Ulead's Cool 3D.
