I am trying to copy DVD-9/DVD-5 using dvdshrink. There is no encryption. I am getting "Cyclic redundancy check error". Any solution or any alternative application to do that function?
Thanks,
shreeit
Check the disc for scratches, fingerprints, general greasy marks etc etc. this usually causes it.
Failing that, try a 2nd drive if you have one. If not, consider one; I would recommend a 2nd drive purely to maximise laser life of the re-writer since they cost more; can use rom to read and then RW to burn. -
Wash disk in water, pat dry.
btw, there are probably 500 messages on this in the forum & you can search & read those, they are neat. -
Your not trying to rip Hitch are you? If so read thread - Hitch generates that error even when the disc is perfect.
By Arch3type in forum ComputerReplies: 6Last Post: 16th Jan 2011, 01:32 -
DVD Lab Pro 2.20 ERROR. Check inside!
By nick_gr in forum Authoring (DVD)Replies: 3Last Post: 28th Jul 2010, 08:54 -
How to correct this Cyclic Jitter ?
By zenzen1 in forum Newbie / General discussionsReplies: 3Last Post: 8th Aug 2009, 18:43 -
I/O Error (Cyclic Redundancy Check) - where does my problem lie?
By xxjustinukxx in forum Authoring (DVD)Replies: 3Last Post: 11th Apr 2008, 21:35 -
Blank Check Command Error In Nero????
By steveuk200 in forum DVD & Blu-ray WritersReplies: 1Last Post: 3rd Jul 2007, 02:31
