Hi,
I would like to be able to watch 2 angles SIMULTANEOUSLY. My current dvd software is powerdvd and I don't think it has this feature. Yes, I can watch different angles separately, but not simultaneously.
Thanks!!!!
Hi,
I don't know if thats possible straight off the disc. You would need two lasers to read simultaneously I would imagine since its off the same point of the disc.
Here's something you could try:
Rip the disc to the harddrive. Then load that into one software dvd player and play the main movie off the dvd. Then if you can synchronize it you might be able to watch it in split windows.
Another option may be to hardcode the video into a split screen from the different angles. I don't know how to do that but I'm sure its possible.
Kevin
PS - of course you could always make a copy of the disc and watch it on a tv next to your monitor so that you have them playing at the same timeDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
hey kevin,
Thanks for the reply.
I dunno. What you say about the laser is probably correct. I have seen those tvs with a picture in a picture. Also, I think some vcrs have it. I wonder in the case of the vcr, if the pick up head has to read two places at once on the tape...
Hmmmm -
Never seen a PIP VCR, do not think those exist.
You need a dual-laser DVD, none exist that I know.Want my help? Ask here! (not via PM!)
You can always edit/author your DVD with the two views visible.
http://www.kiva.org/about -
The only way you would be able to do it would be if you ripped the DVD to hard drive, separate out the different video angles and then used an editing package to overlay the two separate video streams. Save this as a further video stream and play that. An awful lot of work to go to, and expense as any editing package capable of generating PiP images isn't going to be cheap.
A VCR can do PiP but only when the two pictures are coming from different sources, live TV from the tuner and video from the tape. Some have dual tuners so you can watch one channel while recording another so they can show you the output of both tuners. A DVD player doesn't have a tuner and can only play one part of the one disc that is in it so the answer is, no you can't do it.
"Live" picture effect - pictures end up "filmized"
By ANOther1676 in forum Software PlayingReplies: 10Last Post: 14th Oct 2011, 11:59 -
Converter box use and horizontal "waves" in picture
By anet in forum DVB / IPTVReplies: 15Last Post: 16th Jan 2009, 18:42 -
Black and white picture on NTSC television from "region free" DVD
By psears in forum Newbie / General discussionsReplies: 4Last Post: 13th Mar 2008, 13:00 -
Picture "rolls" when trying to grab 60hz footage
By scully1888 in forum Capturing and VCRReplies: 4Last Post: 21st Dec 2007, 04:41 -
Picture "rolls" when capturing (video included)
By scully1888 in forum Newbie / General discussionsReplies: 1Last Post: 15th Dec 2007, 11:52
