    Aug 2003
    los angeles
    have samsung dvd recorder model dvd-r4000..i made a dvd r disc from tv program, finalized it and it plays back on the tv..but i wanted to edit the disc on computer but it will not play back on my dell 4500
    it says"windows cannot read from the disc..it may be corrupted" or else it just sits in the dvd-rom drive with the green light blinking.
    why is this? ive tried several tv recorded discs
    thanks
    Jan 2003
    central NJ
    What brand/model is your Dell DVD drive?
    I read on the Dell website message boards that some of their drives may require firmware updates to read DVD-R disks. You might want to look
    into that.
    Also, what software are you using to view the DVD on the PC?
    My drive came with PowerDVD.
    Aug 2003
    los angeles
    thanks will check it out
    using intervideo windvd
