Just seeing If anyone can tell me how, if possible, to get my recordings off my dvr box into my comp....the only thing i could come up with was firewire..let me Know of any successfull transfers....thanks
Connect the S-Video or composite cables to your capture card, then press play on the remote.
The Firewire output may or may not be active. If you have an HDTV DVR, you can call the cable TV tech, and see if they will activate the port or not. It is software controlled from the firmware file that Time Warner pushes to it. It is up to the specific market area, if that feature is turned on or off. Tell them you have a D-VHS recorder and need to transfer some shows to tape, so you can free up some space on the DVR.
Moto DVR DCT3416 from Comcast - can I get the recordings off the DVR?
By jmkeuning in forum Capturing and VCRReplies: 42Last Post: 7th Jul 2010, 18:44 -
dellE228WFP 22" LCD monitor to a time warner cable box?
By Ashypoo19 in forum DVB / IPTVReplies: 1Last Post: 8th Apr 2010, 15:24 -
A Lump of Coal from Time Warner Cable
By Seeker47 in forum Latest Video NewsReplies: 18Last Post: 4th Jan 2010, 12:35 -
Media Center WITH Time Warner HD cable box - not listed provider
By Brad Bailey in forum Media Center PC / MediaCentersReplies: 0Last Post: 8th Sep 2009, 13:58 -
Time Warner Cable Implements Packet Shaping
By BJ_M in forum Off topicReplies: 6Last Post: 19th Jun 2007, 23:41
