  1. Hi, i have recently purchased a new Sony laptop with DL DVD RW. Although i have yet to try to test DL DVDR's i have burned a couple of DVD-Rs and tried to play in my Sony Dav-S500, but for some reason it says Disc is Dirty and wont play the dvd??
    I have burned dvd's at all speeds using Nero to no avail.
    The media i am using has worked perfectly before when using my other pioneer dvd writer.
    I would really appreciate if anyone could give me any advice or help
  2. What's the drive model? Download DISCInfo and then use File > Save to save a report about your drive. Copy and paste this report into your post.
  3. Hi thanks for the reply! i Have done what you asked and here is the report.
    DISCINFO VERSION : 1.5.5.9
    VENDOR : SONY
    MODEL : DVD RW DW-D56A
    REVISION : PFS3
    VENDOR SPECIFIC : May27 ,2005
    LOADING MECHANISM : Tray
    NUMBER VOL. LEVELS : 256
    BUFFER SIZE : 2048KB
    INTERFACE : ATAPI
    RPC2 SCHEME : YES
    STATUS : Set
    USER CHANGES : 4
    VENDOR CHANGES : 4
    CURRENT REGION : 2
    ANALOG AUDIO PLAY : YES
    COMPOSITE OUTPUT : NO
    DIGITAL PORT-PORT1 : NO
    DIGITAL PORT-PORT2 : NO
    READ UPC CODE : YES
    MULTISESSION READ : YES
    MODE 2 FORM 1 : YES
    MODE 2 FORM 2 : YES
    READ ISRC CODE : YES
    READ BAD CODE : NO
    BUFFER UNDER-RUN : YES
    MT. RAINIER : NO
    CAN READ CDR : YES
    CAN READ CDRW : YES
    CAN READ CDRM2 : YES
    CAN WRITE CDR : YES
    CAN WRITE CDRW : YES
    CAN TEST WRITE : YES
    CAN READ DVD-ROM : YES
    CAN READ DVD-R : YES
    CAN READ DVD-RW : YES
    CAN READ DVD-RAM : NO
    CAN READ DVD+R : YES
    CAN READ DVD+RW : YES
    CAN WRITE DVD-R : YES
    CAN WRITE DVD-RW : YES
    CAN WRITE DVD-RAM : NO
    CAN WRITE DVD+R : YES
    CAN WRITE DVD+RW : YES
    MAX CDR READ SPEED : 24
    MAX CDR WRITE SPEED: 24
    Hope that helps?
    thanks
  4. Member TaoTeWingChun's Avatar
    Jan 2005
    Mahopac, NY
    I'd use some other program to burn DVD's if I were you If you have success with another program then I'd suspect the problem was with Nero's settings somewhere (leaving a session open, for example).
    Post back and let us know how you made ut, ok?
    Cheers!
    TTWC
    "I've got a present for ya!" - TTWC
  5. hey, a bit of good news. I tried burning a dvd with DVD Architect 3, and it worked !! Although that is only one dvd, i hope that will solve the problem.
    However, i'm not sure if DVD Architect 3 will burn dual layer?? coz Nero does and unfortunately Nero is not working well for me??
    Is there a way of checking my settings to ensure everything is set sorrectly in nero, coz that is the programme i have used and am most comfortable with.
    Anyway thanks for the help
