ive read the tutorials i did everything right and it still wont play in my home dvd player but it will load in the pc rom i looked up the dvd player to make sure it can play cd-r and vcd and it can but it still wont work any help would be great thanks.
and BTW the home dvd player is a apex AD-1010W i looked it up on the compatablility list and it plays vcd's
Which guide did you use i.e. what are you using to create the VCD?
Cole -
i used a couple guides in the how to section i just googled my player and i found a site that says my dvd player dosent play vcds but when i did a compatability test on here it says it did so i dont know what it is lol i know it plays mp3's fine and there cd-r disks
burn the vcd on fugi film cd's they usually allways play for me.
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
