Hi, I allready burnt some mpg-vcd files without having any problem, but recently I face some problems with two files!
Im using WinOnCd 3.8 Power Edition, and when i try to copy these files i didnt get the "creating mpg1 track" or something like that (that happens when I get a good burning of a vcd file), and the burning process ends in less than two minutes!! For my surprise it didnt burnt the .dat file! so what i get is only an empty vcd with only the files that says its a vcd!!!
I allready try to fix the mpg file, but when i try to burn the new file it says that is an invalid file!
Please can someone help me with this!
All I can say is to change your burnning software to something elses, like NERO (good for beginners and only if you don't need menu) or VCDImager+TSCV with CDRWIN (with these 2 option you also can create SVCD).
I do have winoncd 3.8 power and eazy 5.0 plat but hate to use them, they make un-usable CD more than usable one especially with vcd.
Burning several mpg files straight to a DVD compliant disk...
By vonsworld in forum Authoring (DVD)Replies: 2Last Post: 5th Dec 2010, 07:25 -
Burning mpg files
By batke in forum Newbie / General discussionsReplies: 3Last Post: 7th Jan 2009, 23:18 -
burning 300 mpg video files on DVD?
By twister6 in forum Authoring (DVD)Replies: 3Last Post: 2nd Nov 2008, 20:02 -
burning a DVD from MPG files
By nick177th in forum Authoring (DVD)Replies: 2Last Post: 6th Sep 2007, 18:36 -
Error burning .mpg files to DL disk
By Anonymous4374945 in forum DVD & Blu-ray WritersReplies: 1Last Post: 22nd May 2007, 08:11
