I've done tons of stuff with AVI editing with VirtualDub which works nicely for commerical editing to me.
But now I have a problem. I have some huge MPEG2 files recording with my WinTV PVR USB2 TV Tuner Card, which range for like 1GB to 30GB. 30GB not because of quality but because I was recording a TV marathon which was 48 hours.
How can I edit the MPEG files by taking out the commercals so I don't have to open them with VirtualDub-MPEG2, waiting like 2 hours for it to actually finish reading it an opening it, then saving it as an AVI, then coverting back to MPEG using TMPGEnc or something else, or maybe just leaving it an AVI using DiVX/XViD in my Panasonic DVP642 DVD Player.
Yes, but even with that, it would take like 2 days just to edit out the commericals and that is if I even get everything done correctly.
Hi there. I would suggest checkin out VideoRedo. I have been using this piece of software quite actively for the past few months primarily for editing out commercials. It is quite fast, accurate, and powerful. Furthermore, the new BETA version has a feature (ad Detective) that automatically scans the MPEG files for commercials which is a nice touch, even though some manual work is required. Although it is not freeware, it is definitely well worth it.
Comskip and Comclean may be worth looking at.
Both command line programs, free.
Look in the forums at www.gbpvr.com
You do not need gbpvr to use these, they'll work on any mpg.Cheers, Jim
My DVDLab Guides
MPEG editing
By mkr10001 in forum Video ConversionReplies: 6Last Post: 16th May 2010, 00:54 -
Keyframes and MPEG-2 editing
By ffooky in forum MacReplies: 8Last Post: 5th Feb 2009, 05:17 -
Commerical DVD v/s DV->DVD quality difference ?
By Movie-Maker in forum Newbie / General discussionsReplies: 6Last Post: 16th Aug 2008, 15:21 -
DVD-R not auto expanding to 16:9 like commerical DVDs
By neilalp in forum Authoring (DVD)Replies: 5Last Post: 13th Feb 2008, 23:04 -
ColorSpace for commerical DVD's
By mlong30 in forum EditingReplies: 6Last Post: 29th May 2007, 21:16
