    Jul 2005
    Canada
    Hi,
    I browsed often you site, I usually find all my answer however, now I don't seem to find the answer to my problem.
    I have an AVI pal, I would like to convert to NTSC, is it possible to do it, if so how?
    I apologize if my question is not relevent to this section, please move it to the right section.
    Regards,
    Sid
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hi,
    Sometimes a little longer search will help. Click here for more options:
    https://www.videohelp.com/convert
    Then scroll for pal to ntsc and you'll find these guides:
    https://www.videohelp.com/guides.php?tools=&madeby=&formatconversionselect=&howtoselect...or+List+Guides
    It's been discussed quite a bit here.
    Kevin
