I'm working out the details on a system I'm building and I'm down to choosing the Mobo and CPU.
This is the Mobo I'm pretty well decided on:
http://www.newegg.com/Product/Product.asp?Item=N82E16813186008
This the the CPU I was going to use:
http://www.newegg.com/Product/Product.asp?Item=N82E16819116141
However after looking at Foxconn's website I'm seeing the lowest speed Northwood listed is 2.4Ghz.
http://www.foxconnchannel.com/tech_compatibilityOverview.cfm?pProject=875A02-6EKRS
Does that mean this CPU won't work for some reason since it's a 2.26Ghz?
If so I'll have to drop an extra $20 on this Proc I guess.
http://www.newegg.com/Product/Product.asp?Item=N82E16819116144
Unless I go with a Prescott. But the Northwoods get so much better reviews and run cooler in this speed range.
Any input is appreciated.
I just built a pc with the Intel 2.53 Northwood processor and a Asus P4P800SE mobo. I backed up 2 movies with DVDRB using the newly built pc. The temperature on the CPU while DVDRB was running only got up to 41C which is good. I would stay with a Northwood core processor because they don't have high temp problems like the PRESHOTT's!
That's likely what I'll end up doing. What is your opinion on the Mobo? I've always heard Foxconn is a good board if you don't plan to overclock, which I'm not on this rig. It also has some feature the others I've looked at don't, like a firewire interface on the mobo, which is nice since the case I bought has a front firewire port.
I'm not too familiar with FOXCONN mobo's. The features look good and the price is reasonable. From reading the rewiews it seems customers are satisfied with the mobo.
I've used ASUS mobo's because they are stable and reasonably priced. They also have good warranties and there aren't hassles in RMA'ing the mobo back to them. -
Foxconn makes the majority of Dell's Mobos are the moment. It that helps or hinders the reputation at all
Gigabyte Mobo, Input/opinions needed... & a Q on ram for new build.
By Noahtuck in forum ComputerReplies: 12Last Post: 28th Aug 2011, 07:30 -
Proc amp before TBC?
By JVRaines in forum Capturing and VCRReplies: 0Last Post: 30th Mar 2011, 16:26 -
mic input -realtime denoise -> sent as input to dragon naturally speakin
By logicom in forum AudioReplies: 0Last Post: 27th Sep 2009, 11:46 -
Will a TBC be useful if i already have this proc amp and detailer?
By HOTPROPHET in forum RestorationReplies: 16Last Post: 9th Jun 2008, 12:04 -
Proc amp? Fix levels at input to Canpus ADVC110
By 2Bdecided in forum Capturing and VCRReplies: 16Last Post: 3rd Jun 2008, 10:31
