I'm using XMPEG to convert DVD to DivX without ripping as I don't have sufficient hard disk capacity to rip the dvd first. I'm getting reasonable results but have a few questions:
1. When I convert a DVD, the end product (either 4:3 or widescreen)is less than the full screen (e.g. a widescreen film is "windowed" at the sides as well as the top. This doesn't happen when I use DVDx - but that gives me all sorts of ausio/video sync problems. Any ideas ?
2. The volume level of the end DivX seems to be pretty hit and miss - sometimes its fine, sometimes it much too low. Not sure if its possible to adjust this during the conversion process (rather than use virtualdub after the event). Any Ideas.
3. Pixel aspect (as opposed to the film aspect ratio) - what does it actually mean and is there a sensible default setting for watching on the pc
4. Lastly, is there a better method for going direct from DVD to DivX without ripping first.
any help on the above questions very gratefully received.
cheers
hrm....are you encoding directly from the dvd in the dvd-rom drive?
if so, it could overheat your dvd and dvd-rom drive and damage both...
3d questions
By alucard2050 in forum DVB / IPTVReplies: 16Last Post: 22nd Aug 2010, 00:01 -
Few questions regarding LCD tv... that will lead to more questions :)
By ohlookyhere in forum DVB / IPTVReplies: 16Last Post: 15th Aug 2010, 16:50 -
Powersupply questions and fan questions
By yoda313 in forum ComputerReplies: 39Last Post: 8th Sep 2008, 19:08 -
Some Yes or No questions
By the_importer in forum Media Center PC / MediaCentersReplies: 22Last Post: 3rd Jul 2008, 19:06 -
Xmpeg help!
By tonydotigr in forum DVD RippingReplies: 6Last Post: 18th Jun 2007, 08:32
