hi guys..i'm gonna buy a digital camera,thing is i have'nt a clue how to go about using one any advice would be appreciated on the subject,will i need any usb cables?what software do i need,how do i get images from the camera to the computer then onto paper?..... :P E.H
This is assuming a still camera, otherwise, never mind.
It should come with the necessary cables and some rudimentary image software. If you want more, one I use is Photoshop Elements. It's reasonably priced, or if you can afford it, the regular Photoshop is one of the best. WinXP has transfer software built in or the software with the camera can do that.
Some things you will need: Spare battery as they never last long enough. A large memory card. 512MB works well and is not too expensive. A good carrying case. I use LowePro. They are well padded and lined with soft fabric. The camera can survive accidental drops much better. -
Memory cards are a must. You can never have enough.
Most cameras come with Photoshop Elements (all of mine have). So you won't need to buy any software if you don't want to. However, regular Photoshop is a whole lot better if you really want it.
USB cables usually also come with the camera so you don't have to worry about that either.
Batteries if you want to. I can usually go at least 3 hours staight on a battery (much more on the SLR but it really uses two batteries).
In XP, the camera will show up as a hard drive. You can just transfer the files. On a Mac, it will also do the same. It will show up as a drive on the desktop and it will open up iPhoto.His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
Actually, most digital cameras aren't set in mass storage mode by default so they shouldn't come up in Windows as an external HDD. However, the Windows wizard should automagically pop up to transfer the images for you.
I personally find it much more convenient to have a USB2 memory card reader attached to the PC rather than connecting up the USB cable to the camera.
As for software, if your camera doesn't come with decent software, then get Photoshop Elements or go the full hog and get Photoshop. I recommend getting a photo sorting program as well. The best that I've seen is Picasa2 and it happens to be free as well.
Regards.Michael Tam
w: Morsels of Evidence -
brilliant guys thanks for the advice,things look a lot clearer now , all i have to do now is spend some money
E.H
I also prefer memory cards too. Mainly because the USB cable is still packaged in the camera box tucked away at the back of the cupboard. Its just more convenient to use the memory card.Originally Posted by vitualis
That too. Since my cam uses USB 2.0 I forget that a lot of them are still 1.1 at best. So, yeah, you will need a card reader for faster transfers.Originally Posted by waheedHis name was MackemX
Digital photography questions
By PartingShot in forum ComputerReplies: 13Last Post: 3rd Aug 2011, 22:42 -
using photography cameras for video...
By nkordyjaka in forum Newbie / General discussionsReplies: 16Last Post: 31st Dec 2010, 19:14 -
Photography of items for website
By Yangster in forum Off topicReplies: 4Last Post: 16th Aug 2008, 18:00 -
Can I use photography lights for video?
By wan2no in forum Newbie / General discussionsReplies: 4Last Post: 15th Jul 2008, 20:54 -
Videohelp for photography?
By anubis13 in forum Off topicReplies: 5Last Post: 27th Jun 2008, 16:49
