Closed Thread
Results 1 to 10 of 10
  1. I've been trying to copy this dvd.. to my hd. Using dvd decrypter. Its had like 20+ read errors. I tried cleaning it using dish wash liquid. But still happens. Is there anyway to improve recovery of this disk. An option in dvd decrypter maybe?
    I'm hoping a small read error. that means maybe 1 or 2 megs of video can't be recovered.. isn't a big deal. Should only amount to like 5 seconds of video or so.
    Apr 2003
    Maryland
    Is this an original store bought DVD. If it is then it is problably a scratch. There are a couple of so called disk polishers but not having ever used these I can not coment on their efficacy. If it is a back up then the copy may have these errors and so, you may not be able to recover. Decrypter has many options to handle errors in their properties. That might help.
    No DVD can withstand the power of DVDShrink along with AnyDVD!
    USA
    In Decrypter, Tools> Settings> I/O> Options. You can set the number of tries higher or have it ignore errors. If the disc is that bad, it's worth a try, but there may be too much missing.
    I would agree to try polishing. If there are a lot of fine scratches, some of the machines work OK. One or two big scratches, I would do by hand with a polishing compound made for the purpose or a lightly abrasive toothpaste. Don't polish in a circle, but back and forth.
  4. Where do you get polish machines? Never heard of that before. Its not a store bought dvd.. its been used before.
  5. Try another DVD-ROM drive or writer.
    -Evan-
  6. Disk polisher definitely worth a shot. If you buy, get the one with a motor instead of a crank. Disk Doctor or some such. Have saved many disks with one of these, crank is a PITA, though.
    If this is by chance a rental disk the scratch may be deliberate, there have been a few posts on the subject.
  7. Ya its a rented dvd. Don't know about it being deliberate lol Some people can be sloppy and careless I'll definitely look for some disk polishers.
    You are in breach of the forum rules and are being issued with a formal warning.
    / Moderator Flaystus
  8. Supreme if you will post your home address here, an official, uniformed agent of the federal government will bring a polishing machine to your house for free.
  9. Member bidefordboy's Avatar
    Nov 2004
    Treasure Island
    Have copied dvd's that have had over 100 read error's using these setting's. On playback just a couple of second's of artifacts. But use as as last resort, try cleaning first.
  10. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    Do not use this site to talk about ripping DVDs that do not belong to you.
