I'm working in the Pinnacle Studio 9 software, so far so good !!!
But when i download their patch for updating to version 9.4.3, everything is going bad.
I can't capture at all, i can't use their plugins for color correction, because then it goes like slow motion.
I have uninstalled and installed again, but the problems is still there. I have a brand new Fujitsu Siemens computer, so the problem is not there.
I have talked with Pinnacle, and they have no more suggestions for me.
Does anybody have a solution i can use ??
Graphic Designer from Denmark
I've heard that that patch is causing problems with users. I am one of the lucky one I guess.
Uninstall and remove the pixie folder as well as reg entries. Folder is in Documents and Setting/All Users/Pinnacle. Reinstall and don't update. Did you have access to ALL functions in the past but not after the patch? Did you have full function on HFX or just demos?No DVD can withstand the power of DVDShrink along with AnyDVD!
KeepVid is not working properly
By Cunhambebe in forum Newbie / General discussionsReplies: 8Last Post: 18th Apr 2011, 15:07 -
convert x not working properly
By paullyon in forum Newbie / General discussionsReplies: 3Last Post: 24th May 2010, 09:41 -
mkv's not working properly
By runLoganrun in forum Blu-ray RippingReplies: 2Last Post: 7th Dec 2008, 13:13 -
Video Not Working Properly
By RamEEz in forum Newbie / General discussionsReplies: 4Last Post: 9th Apr 2008, 19:23 -
Video and subtitles not working properly
By MaddenPT in forum SubtitleReplies: 5Last Post: 8th Jan 2008, 02:26
