Hello all.
I currently have video files (xvid) which I wish to cut parts out of, then join back together. I used Ultra Video Splitter to break the file apart, and the two seperate pieces seemed fine. However, when I then used Ultra Video Joiner to merge the parts, the second part loses audio sync.
I have read in various places that this happens when the audio stream on the first file is very slightly shorter than the video stream.
What I would like is suggestions for any software (freeware, shareware, and commercial, please) which can carry out these operations (both the splitting and the joining) without ruining the audio sync. I also need the software to be able to read, and right files using, the xvid codec.
Thanks,
Ian
First, check out the extensive sticky on "why does my file lose audio synch".
Mpeg files are fairly easy, and there are lots of choices, mainly because MPG is a standardized format, little variation in audio file types.
XVID, and variants of MPG4, is a different story. Large number of different audio codecs and formats, a prog may handle one type but not another. VBR audio encoding is a major problem. Often two segments to be joined will use different audio encoding methods and formats. No one solution will handle all these different problems, most of which will lead to audio de-synch.
Basic solution, found years ago, and detailed MULTIPLE places on this board, is to strip the audio as a WAV file, join the two vids, and re-encode the audio. This will almost always work.
How do I edit, cut, join DVDs, VOB, VIDEO_TS folders
By Baldrick in forum Authoring (DVD)Replies: 13Last Post: 9th Oct 2013, 06:03 -
AVStoDVD ERROR DURING OPERATIONS ('DVD Authoring operations' Section): 0
By avitodvdbabe in forum Authoring (DVD)Replies: 0Last Post: 22nd Oct 2011, 16:14 -
mpeg4-ts - how to edit? Need to cut fragments and join two files
By relu84 in forum Newbie / General discussionsReplies: 2Last Post: 18th Jan 2011, 07:01 -
Easiest way to cut and join video files
By zammil in forum Newbie / General discussionsReplies: 8Last Post: 15th Oct 2010, 12:04 -
Cut and Join VCD Files: tools that can Handle that
By devilcoelhodog in forum Authoring (VCD/SVCD)Replies: 5Last Post: 15th Jan 2010, 21:57
