Results 1 to 9 of 9
  1. I tried to use DVD Shrink to back up two different movies, but got a burn fail on both. I have tried to use two different media, Sony and Verbatim. Following is my system info:
    PC with P4 2.0 ghtz and 768m RAM
    Windows XP w/SP2
    Using Pacific Digital DVD +/- R/RW
    Can somebody tell me what the following long error log means? Thank you in advance for any assistance.
    Log:
    1A22-020K-0530-1349-1219-9976
    Windows XP 5.1
    IA32
    WinAspi: File 'Wnaspi32.dll': Ver=?.?.?.?, size=30208 bytes, created 6/11/1997 8:01:02 PM
    ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 10/26/2004 6:35:34 PM
    Nero Version: 6.6.0.15
    Internal Version: 6, 6, 0, 15h
    (Nero Express)
    Recorder: <DVDRW IDE1004> Version: 0049 - HA 1 TA 0 - 6.6.0.15
    Adapter driver: <atapi> HA 1
    Drive buffer : 2048kB
    Bus Type : default (0) -> ATAPI, detected: ATAPI
    CD-ROM: <LITEON DVD-ROM LTD163 >Version: GDHF - HA 1 TA 1 - 6.6.0.15
    === Scsi-Device-Map ===
    DiskPeripheral : MAXTOR 6L040J2 atapi Port 0 ID 0 DMA: On
    DiskPeripheral : WDC WD1600JB-00EVA0 atapi Port 0 ID 1 DMA: Off
    CdRomPeripheral : DVDRW IDE1004 atapi Port 1 ID 0 DMA: On
    CdRomPeripheral : LITEON DVD-ROM LTD163 atapi Port 1 ID 1 DMA: On
    === CDRom-Device-Map ===
    DVDRW IDE1004 D: CDRom0
    LITEON DVD-ROM LTD163 E: CDRom1
    AutoRun : 1
    Excluded drive IDs:
    WriteBufferSize: 83886080 (0) Byte
    ShowDrvBufStat : 0
    BUFE : 0
    Physical memory : 767MB (785412kB)
    Free physical memory: 391MB (400956kB)
    Memory in use : 48 %
    Uncached PFiles: 0x0
    Use Inquiry : 1
    Global Bus Type: default (0)
    Check supported media : Disabled (0)
    25.7.2005
    ISO compilation
    9:57:00 AM #1 Text 0 File Isodoc.cpp, Line 6314
    Iso document burn settings
    Determine maximum speed : FALSE
    Simulate : FALSE
    Write : TRUE
    Finalize CD : TRUE
    Multisession : FALSE
    Burning mode : DAO
    Mode : 1
    ISO Level : 1 (Max. of 11 = 8 + 3 char)
    Character set : ISO 9660
    Joliet : TRUE
    Allow pathdepth more than 8 directories : TRUE
    Allow more than 255 characters in path : TRUE
    Write ISO9660 ;1 file extensions : TRUE
    9:57:01 AM #2 Text 0 File Reader.cpp, Line 127
    Reader running
    9:57:01 AM #3 Text 0 File Writer.cpp, Line 122
    Writer DVDRW IDE1004 running
    9:57:01 AM #4 ISO9660GEN -11 File geniso.cpp, Line 3309
    First writeable address = 0 (0x00000000)
    9:57:01 AM #5 Text 0 File Burncd.cpp, Line 3231
    Turn on Disc-At-Once, using DVD media
    9:57:04 AM #6 Text 0 File DlgWaitCD.cpp, Line 269
    Last possible write address on media: 2298495 (510:46.45, 4489MB)
    Last address to be written: 2264303 (503:10.53, 4422MB)
    9:57:04 AM #7 Text 0 File DlgWaitCD.cpp, Line 281
    Write in overburning mode: NO (enabled: CD)
    9:57:04 AM #8 Text 0 File DlgWaitCD.cpp, Line 2477
    Recorder: DVDRW IDE1004, Media type: DVD-R
    Disc Manufacturer: SONY08 - D1
    Disc Application Code: 64, Disc Physical Code: 193
    9:57:04 AM #9 Text 0 File DlgWaitCD.cpp, Line 447
    >>> Protocol of DlgWaitCD activities: <<<
    9:57:05 AM #10 Text 0 File ThreadedTransferInterface.cpp, Line 830
    Setup items (after recorder preparation)
    0: TRM_DATA_MODE1 ()
    2 indices, index0 (150) not provided
    original disc pos #0 + 2264304 (2264304) = #2264304/503:10.54
    relocatable, disc pos for caching/writing not required/ required, no patch infos
    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2264304 blocks [DVDRW IDE1004]
    9:57:05 AM #11 Text 0 File ThreadedTransferInterface.cpp, Line 1043
    Prepare recorder [DVDRW IDE1004] for write in CUE-sheet-DAO
    DAO infos:
    MCN: ""
    TOCType: 0x00; Session Closed, disc fixated
    Tracks 1 to 1:
    1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4637294592, ISRC ""
    DAO layout:
    __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
    0 | lead-in | 0 | 0x41 | 0x00
    0 | 1 | 0 | 0x41 | 0x00
    0 | 1 | 1 | 0x41 | 0x00
    2264304 | lead-out | 1 | 0x41 | 0x00
    9:57:06 AM #12 Phase 24 File dlgbrnst.cpp, Line 1832
    Caching of files started
    9:57:06 AM #13 Text 0 File Burncd.cpp, Line 4116
    Cache writing successful.
    9:57:06 AM #14 Phase 25 File dlgbrnst.cpp, Line 1832
    Caching of files completed
    9:57:06 AM #15 Phase 36 File dlgbrnst.cpp, Line 1832
    Burn process started at 4x (5,540 KB/s)
    9:57:07 AM #16 Text 0 File ThreadedTransferInterface.cpp, Line 2643
    Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
    9:57:07 AM #17 Text 0 File DVDR.cpp, Line 2357
    Recording mode: Sequential Recording Mode
    9:57:08 AM #18 Text 0 File Mmc.cpp, Line 21663
    Set BUFE: Super Link -> ON
    9:57:08 AM #19 Text 0 File DVDR.cpp, Line 2511
    Start write address at LBA 0
    DVD high compatibility mode: Yes
    9:57:08 AM #20 Text 0 File Cdrdrv.cpp, Line 8821
    ---- DVD Structure: Physical Format Information (00h) ----
    Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
    Book Type: DVD-R (2), Part Version: 5
    Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
    Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
    Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
    Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
    End Physical Sector Number of Data Area: 0 h
    End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
    Data in Burst Cutting Area (BCA) does not exist
    Start sector number of the current Border-Out: 0 h
    Start sector number of the next Border-In: 0 h
    Media Specific [16..63]:
    00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
    9:57:53 AM #21 Text 0 File Cdrdrv.cpp, Line 1288
    09:57:53.296 - DVDRW IDE1004\H1 T0 : Queue again later
    10:02:08 AM #22 SCSI -1135 File Cdrdrv.cpp, Line 1436
    SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x0C310000
    Status: 0x04 (0x01, SCSI_ERR)
    HA-Status 0x00 (0x00, OK)
    TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
    Sense Key: 0x03 (KEY_MEDIUM_ERROR)
    Sense Code: 0x0C
    Sense Qual: 0x00
    CDB Data: 0x2A 0x00 0x00 0x00 0x0F 0x00 0x00 0x00 0x20 0x00 0x00 0x00
    Sense Data: 0x71 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
    0x00 0x00 0x00 0x00 0x0C 0x00
    10:02:08 AM #23 CDR -1135 File Writer.cpp, Line 311
    Write error
    10:02:08 AM #24 Text 0 File ThreadedTransfer.cpp, Line 228
    all writers idle, stopping conversion
    10:02:09 AM #25 Text 0 File ThreadedTransfer.cpp, Line 222
    conversion idle, stopping reader
    10:02:09 AM #26 Text 0 File DVDR.cpp, Line 2749
    EndDAO: Last written address was 3839
    10:02:23 AM #27 Phase 38 File dlgbrnst.cpp, Line 1832
    Burn process failed at 4x (5,540 KB/s)
    Existing drivers:
    File 'Drivers\ADPU160M.SYS': Ver=v3.60a (Lab01_N(johnstra).010529-2218), size=101888 bytes, created 8/4/2004 5:00:00 AM
    File 'Drivers\CDRALW2K.SYS': Ver=7.0.0.162 , size=24576 bytes, created 2/26/2004 7:58:32 AM
    File 'Drivers\ASPI32.SYS': Ver=4.71 (0001), size=17005 bytes, created 8/14/2002 4:03:36 PM
    File 'Drivers\PXHELP20.SYS': Ver=2.02.40a, size=16416 bytes, created 10/1/2002 11:02:00 AM (Prassi/Veritas driver for win 2K)
    File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 8/4/2004 5:00:00 AM (Adapter driver for rec)
    Registry Keys:
    HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
  2. Member e404pnf's Avatar
    Dec 2004
    Warmington on Sea
    Are trying to use DVD Shrink straight from the disk? If so it may be worth ripping the files to your hard drive first and then shrinking. Try DVD Decrypter or FAB DVD to do the ripping.
    If you are doing this what movie are you trying to shrink and what s/ware did you rip with?
    - e404pnf
  3. Thanks for the response.
    For this particular fail I did not use another ripper, but I got the same problem when I tried to rip using DVD Decryptor. I tried to do Coach Carter and National Treasure, both movies gave me problems. I tried both of them multiple times, though I used Decryptor only on Coach Carter.
  4. Member e404pnf's Avatar
    Dec 2004
    Warmington on Sea
    Sorry, just read your question properly - DVD Shrink is running ok you just have burn error .
    In the DVD Shrink settings are set to burn with Nero? If so try creating an ISO image and then burn with DVD Decrypter afterward.
    Could also be a media issue, try looking in the DVD Recorder section for media for your burner.
    - e404pnf
  5. Your problem is more than likely with Nero.
    Whenever I see a post regarding failed burns Nero always seems to pop up.
    As previously recommended create an ISO image in DVDshrink and burn to disc with DVDdecrypter, this will more than likely rectify the problem.
    I dont think your choice of media will be the problem as Sony and Verbatim should be fairly reliable.
    I have seen a few people complain that version 6 of Nero has given them problems burning DVD's and they have returned to an earlier version and had no problems.
  6. Thank you all for your help. Can somebody give me a quick and dirty rundown of how to create an ISO file, maybe a quick explaination of what one is. I was not even aware that I could burn a disc using DVDdecrypter. Also, if Nero is not a particularly good burner to use with Shrink, what would be a good alternative?
    Thanks Again
  7. Member TaoTeWingChun's Avatar
    Jan 2005
    Mahopac, NY
    Check out the following link on using DVDShrink to create ISO images:
    http://www.doom9.org/index.html?/mpg/dvdshrink31-main.htm
    An ISO image is basically a disc-ready image that contains all of the necessary files/folders in a ready-to-burn format.
    As for burning ISO's, I use TDA or DVD Decryptor for ISO's to DVD.
    Cheers and best of luck!
    TTWC
    "I've got a present for ya!" - TTWC
  8. Originally Posted by kiruk
    Thanks Again
    Just use DVDdecrypter.
    In DVDshrink when you select to 'Backup' you can select to create an 'ISO image and burn using DVDdecrypter' as an option.
    it's as easy as that.
  9. Thanks for everybodies suggestions. I did a movie yesterday choosing the create ISO and burn with DVDecryptor and it worked perfectly. I appreciate the advice.
