I have a non copyrighted .mpg file (which was edited/developed on a PC) that I would like to import into either iMovieHD or Final Cut Express to edit. After looking through several web sites it seems that I need to install and run ffmpegX however I have been unable to properly install it. I continually get an error that says it can't find Library/ApplicationSupport/ffmpegX. I followed instructions on another help site that instructed to do the following in Terminal.app:
sudo mkdir /usr/local && sudo mkdir /usr/local/share && sudo mkdir /usr/local/lib && sudo mkdir '/Library/Application Support/ffmpegX'
This instruction came from "majorr" whom I think is the souce of ffmpegX.
First question, is this the correct software to use to convert a .mpg or .wmv file to .mov so that I can import into iMovieHD or Final Cut Express for editing?
Second question, is there something better to capture and convert files in order to edit said files?
I have also explored using MacTheRipper. Third question, will MacTheRipper capture/convert files for editing in iMovieHD or Final Cut Express.
Thank you for any and all information you can provide.
Oh, I am using a G4 Powerbook w/ 10.4.2 OS.
converting from mpeg2 or wmv to a format for idvd or final cut express
By jbrown23 in forum ffmpegX general discussionReplies: 2Last Post: 8th Mar 2011, 21:23 -
converting hd (mts) file to final cut express 4
By ang03207 in forum Video ConversionReplies: 3Last Post: 24th Aug 2010, 00:34 -
convert h.264 to use in Final Cut Express. Streamclip problem
By robinhall in forum Video ConversionReplies: 2Last Post: 28th Mar 2010, 15:54 -
convert H.264 to use with Final Cut Express. Streamclip problem
By robinhall in forum MacReplies: 1Last Post: 28th Mar 2010, 15:41 -
With a mac how do I convert a Final Cut Express item to mpeg2 dvd?
By dagardenguy in forum ffmpegX general discussionReplies: 2Last Post: 16th Jan 2009, 12:00
