Hey
So I know this forum seems pretty well dead, but I'm hoping someone sees this.
I've been using GUI4FFMPEG rather successfully, though infrequently to convert my AVI/XVID files to mpg but I've run into this issue twice. First time something corrected itself, but this time I can't seem to get around it.
What happens is that after I follow the guide each step precisely and hit the encode button, the DOS screen pops up and then disappears. Nothing seems to indicate the process starts or stops or anything. I then, maybe foolishly, repeatedly hit the Encode button and I see that the DOS screen says something, but I really can't read it because it disappears so fast. I think it says something about something not being supported.
Can anyone help me? Just tell me what other info I need to supply...
Results 31 to 42 of 42
Fantasma
please open gui4ffmpeg, make your settings and press the Generate button.
This creates the ffmpeg command string. Copy this string. Open a DOS box and
paste the copied string. So you'll see, what is happend with your command.The home of the sun - http://www.blueview.de.vu -
I did exactly as you said, and now the process is running. Thank you so much for getting back to me so quickly!
I did manage to find out what the DOS prompt was saying after many trials yesterday: 'cmd' is not recognized as an internal or external command, operable program or batch file.
Since then, I have set about scanning my system to check things over.
Thanks again so much for helping me out! -
I just started using gui4ffmpeg and it is working great. Now, is there a way to convert multiple files at once? I have about 10 files that I want to convert, and it would be nice to set them to go automatically one after the other - rather than having to sit next to my computer and re-run the program every 10 or 15 minutes.
Thanks! -
chuy346
Load your first file and make your settings. Go to "Batch" in the menu
and choose "Add current command".
Load your second file and make the settings. Go to "Batch" in the menu
Repeat this procedure with all your files.
If finished, go to menu and choose "Run batch file".The home of the sun - http://www.blueview.de.vu -
I have multiple avi. I need to combine them and then convert them to DVD. Do I have to combine the avi with some software or can I use gui4ffmpeg13 to convert and combine at the same time?
Usually this program works very well for me. However, I have found that when converting some files, they stop midway through converting (at approximately 300MB), this causes my computer to slow down a lot too. This has happened with british TV shows Big Train and Peep Show. Can anyone help?
Hi..
I am jus tryin to use this s/w and til now it works gr8..nw the output wil be a mpeg file..hw to write these files as Video DVD..
Can i use Nero to take these files and write them as Video DVD or is thr any other s/w to mk Video DVD..
Help needed pls..
TIA-=[ Prepare 2 B Compressed ]=- -
hi...i dont know if anyone checks this anymore, but i just got gui4ffmpeg and converted a DivX file (2000 MB) to a mpg (700 MB) for a DVD. Unfortunately, the quality has gone waaaay down. Has anyone else had this problem or know how to fix it?
thanks -
I'm having the same problem as tombombca.
Trying to convert a divx avi of 349MB into a DVD compliant mpg. The resultant file is 250MB, and is extremely blocky and pixellated.
I followed the instructions at the start of this thread, so i'm a bit puzzled.
I did notice that when I selected the source file, gui4ffmpeg didn't display any attributes of the file at all.
Any help with this would be very gratefully received. Thanks! -
Quality in gui4ffmpeg
In the newest versions of ffmpeg the video bitrate must be entered in bit/s.
Gui4ffmpeg uses the old kbit/s. Please enter in the video bitrate field the
value as bit/s (e.g. 6000000 instead of 6000).The home of the sun - http://www.blueview.de.vu
How to convert a multi-feature DVD to DivX/XviD with ease using freeware
By Cheekie_Moonkie in forum User guidesReplies: 160Last Post: 17th Dec 2011, 03:26 -
Convert DVD into DIVX / XVID using FairUse
By p_uriel in forum Video ConversionReplies: 1Last Post: 19th Jan 2011, 17:26 -
How to encode DVd to DIVX with gui4ffmpeg
By gui4ffmpeg in forum User guidesReplies: 32Last Post: 21st Nov 2008, 05:02 -
What is the fastest way to convert XVID/DIVX TO DVD
By goheadtry in forum Newbie / General discussionsReplies: 8Last Post: 23rd Nov 2007, 09:33 -
I need to convert dvd into avi!not xvid or divx!
By picky2112 in forum DVD RippingReplies: 5Last Post: 6th Jul 2007, 03:22
