I received a DVD instructional video from the manufacturer of a bike that I recently purchased. But the DVD can only be played in a DVD player and not in a computer. I don't have a DVD player. We use my wife's iBook to view DVDs on TV.
When I load the DVD in my PowerMac G5, with Pioneer 109, it does not load in the finder. Toast sees it, and so I tried copying it, but the copy is "locked" just like the original.
MacTheRipper doesn't register that there is a disc in the drive.
VLC gets the disc spinning via command+D (open disc), but nothing comes up.
Apple's DVD Player doesn't see it.
Is there anyway to view the DVD on my Mac?
Results 1 to 12 of 12
Sounds like it might be DVD-RAM or that it might be
DVD-VR recorded.
You say Toast "saw" the DVD, and you were able to copy it.
What if you made a disc image of the DVD using Toast?
Would the DVD disc image then mount on your G5?
If so, then you should be able to rip it via MTR, and then
burn it back to disc."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
after putting the DVD in the drive, open toast and then the toast menu under 'recorder' disk info
a window opens and tells you whats in the drive.
aslo you could check sys profiler when its in the drive.
very curious if toast sees it
let us know
thanks rotutsMPro 2.66 3GB RAM 1.5TB HD's
MigliaMiniHD
QTPro, MPEG2 add on MPlayerX2
MPEG Streamclip
24 + 21" samsung flat panels
G4dual 2GB
AlchemyDVR card -
Under the 'recorder' menu in Toast, the disc information reads under the 'Type' column:
Data (Hybrid)
ISO-9660
Per Terryj's suggestion, Toast was able to save it to a disc image, I think. the result was a 2.2GB file named "<no volume>.toast". I double clicked on it and it showed up in Toast under the 'Copy' tab and below the file name, "2.2 GB UDF Bridge DVD". When I clicked the 'Mount' button in Toast, nothing happened.
MTR doesn't show anything. -
I tried control clicking on the <no volume>.toast file and tried opening with "DiskImageMounter" but the file has "no mountable file systems".
I opened up Disk Utility and it showed either the disc or the disc image from toast in the left left column. I control clicked on it and chose 'information'. A window opened with the following:
Name : Roxio, Inc. disk image Media
Type : Disk
Disk Identifier : disk6
Media Name : Roxio, Inc. disk image Media
Media Type : DVD-ROM
Connection Bus : ATAPI
Connection ID : Device 0
Locked : Yes
Writable : No
Ejectable : Yes
Mac OS 9 Drivers Installed : No
DVDROM : Yes
Optical Media Type : No Media
Total Capacity : 2.2 GB (2,323,742,720 Bytes)
Disk Number : 6
Partition Number : 0 -
You'll need something to edit the IFO then,
so you can unlock it.
Gumby maybe?
something similar to ISO Buster?
wait a minute...you said you could get a disc image created.
Can Disk Utility mount it? In your utilities folder?
basically, we have two ways of doing this:
hard--Get something to eidt the ISO so you can unlock it
( the one created by Toast)
easy--Get the VOBs off the disc, by getting it mounted,
and extracting the .VOBs"Everyone has to learn, so that they can one day teach."
Urban Mac User -
Im betting Terr is your guy on this but let me add what I can
I hve a few DVD's made with a Sony VCR -> DVD recorder. they start or stay as Sonata for the DVD label in the computers desk top unless you tell the DVD recorder to title them differently.
they appear on the desktop and apples dvd player will play them but toast on checking the info through it does not know what they are and says:
cound't read the table of contents. the disk may be damaged.
so toast won't deal with these disks. there is comerial software for this bnut I do not recall the link, but thats not for the type of disk you have.
you have to see what the file type is on the Iso disk and I don't khnw how to look into that
when the disk is in the comp what does apple sys profile say about it?
bet terr does and he will reply when he gets around to it.
Im betting you are out of luck. can you try it on an UGGHHH PC?
rotutMPro 2.66 3GB RAM 1.5TB HD's
MigliaMiniHD
MPEG Streamclip
G4dual 2GB
AlchemyDVR card -
I changed the file name to breakaway.img. Then I opened the disk image with Disk Utitliy. The image shows up in DU, lower left column and the "mount" feature is no longer grayed out. However, when I select the image and click mount, nothing happens.
I've downloaded ISO Buster. I'll try that via VPC7 tomorrow. It's 1:30AM right now...I live in China. Thanks for your help!!!
We'll see how it goes tomorrow. -
Ok, I changed my mind and stayed up. I installed ISO Buster in VPC and it's extracting the VIDEO_TS folder as I type this.
I assume that I should use MTR once ISO Buster is finished, then burn with Toast? -
yes, That is what I thought...that the IFO would need to
be edited...and unfortuantely, ISO Buster is the only app
I know of that could do it....Glad it is working!
Your Welcome...!
and yes, MTR will NOT be needed, as the disc being locked
is a feature of the IFO structure, much like locking a disc
partition in the OS, instead of a true "copy protection"
scheme like ArCCos or Macrovision. Locking the disc was
a poor man's way of "protecting" it.
how to make a video "stickin" to a certain view (frame)?
By Srivas in forum EditingReplies: 17Last Post: 14th Jan 2012, 10:11 -
How to view files on "empty" 16GB memory stick
By jimdagys in forum ComputerReplies: 15Last Post: 15th Dec 2011, 08:35 -
Can't view "bonus video content" on Taylor Swift CD
By wild4trv30 in forum DVD RippingReplies: 11Last Post: 18th Jul 2011, 13:22 -
"Sharp BD-HP21S" - How to unlock the region code?
By hoklik2 in forum Newbie / General discussionsReplies: 1Last Post: 15th Feb 2011, 13:12 -
Is it possible to change the default "Open" view?
By SLK001 in forum ComputerReplies: 5Last Post: 22nd Oct 2008, 12:38
I'm viewing the VIDEO_TS folder via Apple's DVD Player. I'll burn the folder with
