Results 1 to 10 of 10
  1. I'm having problems playing DVD's using PowerDVD XP. When a disc is played, it just resizes the playback window, then resizes it back to the empty window. Interactual player and Media Player will recognize and play the DVD's, but I can't get anything to work with PowerDVD.
    The drive is a Pioneer 105s with no region coding... could this be the problem? Anyone else experiencing anything similar, or more importantly, have a solution?
  2. Member Dhruv's Avatar
    Aug 2001
    Australia
    Try reinstalling PowerDVD XP.
    I only dream in black & white...
    MSN: paschendale@gmail.com
  3. I did, a few times. Also trying to find conflicts with other software (or video codecs), so far to no avail.
  4. use 800x600 resulution. It was only resolution that worked with my computer properly.
    Sep 2001
    Japan
    Hav eyou tried both modes (disc and file)?Have you tried to play one of the .vobs in file mode?Have you run the dma test and other test from PowerDVD.What about Audio/Video settings: do they fit?Have you optioned a HW accelarotor without having one?
    Feb 2001
    Palmdale, CA
    I am using powerdvd 3.0 under xp with no problems, not even thinking about upgrading.
  7. The only two features i found usefull in the XP 4.0 version is the ability to auto play SVCD and to skip in Chapters, other then that, it's the most unstable version I saw.
    You might as well use WinDVD v3.1
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
  8. not running under win xp, but nevertheless a question about (s)vcd players, i need one that needs little processing power yet recognizes and plays (s)vcd's including menu structures etc.
    any suggestions?
    ... this copy of me hasn't been registered for the last 36 years! (no spamming please)
    Feb 2001
    Palmdale, CA
    easy question, STHSVCD, look under tools, it's free and it works great.
  10. thanks, i'll try it
