    Jun 2005
    Australia
    I have a great .vob file with ac3 5.1 audio. After much trial and tribulation I now have a mpeg2 file with ac3 5.1 audio of sufficient size to put onto a dvd-r. But I can't do it. Sizzle seems to be working but then makes a disc image that is only 32mb with the start of the movie only.
    I have had other problems with ac3 audio, including the centre channel being placed to the right, but the affects seem fine. I found that simply passing the audio throught using the ffmpeg mpeg 2 encoder it all worked.
    Any thoughts?
    Cheers,
    Dipster
  2. Sometimes Sizzle has issues with ac3. If you can find the older version, it should work fine.
    Jun 2005
    Australia
    Well I could't find a previous version of Sizzle, so I went and bought POPCORN. Seems to work a treat.
    Thanks for the replay and help.
    CHeers,
    Dipster
