I have Vegas, and virtual dubmod. Do either of those have the functionallity to record a clip in reverse. I am wanting to edit a video that will move the same frames back and forth.
Results 1 to 13 of 13
I am unable to figure this one out. Can you describe where I am supposed to click?select a region on the timeline in vegas
Thanks for the replies -
region/selection these items are interchangeable in this instance. When you highlight a selection in the timeline, you can then do particular edits of that.
YOu can in that selection, make it a region by typing R on the keyboard. green markers will be placed at start and end points, or you could press S and it will split that selection from other areas. Or you could use the context menu and select "create subclip", which will copy that region to a new file, but still keep the same position in the timeline. Creating subclip means that edits are done only on that portion without the need to use the original file.
hope this helps.Some people are only alive because it may be illegal to kill them -
Call me an all out NOOB, but am I using the right version? 4.0 is what I am using and I cant find an option for create or subclip. Can copy and then paste at the end of the set of frames work? From there, where can I find the reverse option. Hope I am not trying your patience.
Ok. That explains my confusion. I will get latest version then follow your instructions. Thanks again.
In premiere (for those that would like to know using Premiere) right click on the video on the timeline... select speed/duration, check the box that says reverse speed and wah lah.. done deal!
I would use the razor tool to cut the in and out points and just reverse the part I want, or speed up or slow down etc.. etc..
Loss of frames when playing mkv/mp4 etc
By periodrage in forum Software PlayingReplies: 6Last Post: 16th Jan 2011, 16:45 -
Movies playing is reverse sequence
By Kusotate in forum Newbie / General discussionsReplies: 2Last Post: 18th Nov 2010, 19:18 -
FLV skips few frames back and forth while playing
By Mylo in forum Video Streaming DownloadingReplies: 3Last Post: 2nd Apr 2009, 22:56 -
CaptyDVD discs not playing right--dropping frames
By KMJvet in forum MacReplies: 5Last Post: 9th Nov 2007, 18:55 -
.avi file not playing all the frames
By xiaofeng in forum EditingReplies: 3Last Post: 24th May 2007, 15:51
