DvdDecrypter tells me "There doesn't appear to be enough space on the disc to burn this image.
Image size: 2,298,336 sectors
Disc size: 2,295,104 sectors
I never got this problem before, and ive burned this same image before w/ another disc of the same brand. Ive tried 5 diff discs from the spindle and get the same error, any ideas?
what media are you using?
What We Do In Life, Echoes In Eternity.... -
im using TY 8x media. oh btw... if i move the image to my C drive from my D drive, its burnable. For some reason things look bigger on my D drive. ANy ideas what happened to this harddrive?
Originally Posted by BBock727
It may simply be reporting incorrectly (for whatever reason).
And it may well work especially if the image works from a differnet location..... -
How did you generate the ISO? For one or two of the ISO I have generate using the ISO>Read function of DVD Decrypter when I try to load the ISO to burn on to a new disk I get the insufficient space error but when I load the .MDS that DVD Decrypter generates it burns fine.
- e404pnf -
Originally Posted by e404pnf
Decrypter has even propmted me to do so!
(tho i tend to delete the MDS so that it cant use it and point it to the ISO!! <G>) -
Originally Posted by zworg2
. I think older versions of DVD Decrypter used to prompt you to (and then automatically select) the MDS file but the latest doesn't.
- e404pnf
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 05:27 -
1. Need advice: Burning DVD from Flash Drive mP4 2. DVD-R vs. DVD+R
By Ronald Vaughan in forum Newbie / General discussionsReplies: 1Last Post: 14th Jul 2010, 14:53 -
Iso burning faile, folder burning succeed
By cd090580 in forum DVD & Blu-ray WritersReplies: 5Last Post: 3rd Dec 2009, 14:46 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 15:19
