Hello,
I have a video file that has no audio. When i load up the file in Gspot, it says the following:
Audio: ac3 (0x2000) Dolby, 448 kb's 5 ch (CBR), 48000 Hz. It says the proper codec is installed (Nero Digital Audio Encoder).
Video: xvid, 640x272, bitrate: 1265, fps: 23.976
Stream Type is OpenDML AVI.
My speakers are on and functioning with other audio files as well as other video files with audio.
Any ideas as to why this is happening?
Thanks in advance.
LG
Looks like you need a decent AC3 decoder - I have used AC3 Filter for a while and it works very well.
Link : https://www.videohelp.com/tools?tool=AC3_Filter
One bit of advice though, I find that sometimes the volume is very low. You can fix this by adjusting the gain in the filters config.Who is watching the watchers. -
nzjacob:
Thanks for the reply
I took your advice and downloaded this codec. It didnt seem to do anything. However, I raised the volume on my speakers too full and then the volume on my media player to full and heard volume, finally. So I am unsure if the filter actually helped. If i play anything else this way, its loud, to say the least.
Now, you metioned the low volume and I could edit it in the config filters. Except when i go into the directory for the ac3 filter, there isnt any application file that i can open the filter with (I'll assume thats where i was supposed to open it).
Any more advice?
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 06:36 -
RipBot264 Audio Problem (no audio)
By fefalas in forum Video ConversionReplies: 9Last Post: 8th Apr 2011, 10:39 -
Help With Audio Problem please!
By heidilynn08 in forum AudioReplies: 3Last Post: 16th Dec 2010, 11:08 -
audio problem
By harariman in forum AudioReplies: 10Last Post: 7th Jan 2009, 21:31
