    Jul 2005
    USA
    Is there a way to tell if the format is PAL OR NTSC before downloading it or after downloading part of the file.
    Qali
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hi,
    Well one clue is what country code the website is. If its a foreign (ie not us) website than chances are its pal. If its north america or japan it will be ntsc.
    Of course some sites will have clips from anywhere. You can use gspot to tell after you download of course.
    Kevin
  3. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    I know when downloading a WMV within Media Player you can find out that information by clicking file>properties while it's downloading. Don't know if it will give it for mpeg or other formats.
