Page 2 of 2
FirstFirst 1 2
Results 31 to 43 of 43
  1. Originally Posted by G Rom
    Greaaaaaat !
    Thank you major.
    In fact, QuickTime 7-compliant H.264/MP4 is all I need
    Aye, talk about a welcome feature. I'm glad things are moving along so well for you Major, your work is really appreciated. By a hell of a lot of us
    Aug 2005
    Bay Area
    Hi Major, great job on ffmpeg, very handy tool.
    I was wondering if you could tell us if there are any command-line options we could use in the meantime in order to batch out a bunch of conversions? I've got several hours of footage, all in .asf format and I would like it in quicktime. Thanks.
  3. Member G Rom's Avatar
    Aug 2005
    Montpellier, France
    Originally Posted by major
    I wanted to make a surprise! Well, yes I'm finally adding Quicktime 7-compliant H.264/MP4 (not MOV!) to 0.0.9t. This will take a couple more days. I don't know if PSP H.264 will be also included in this version, as the format seem to be a little different.
    Major,
    Does it use ffmpeg or mencoder to create H.264/MP4 ?
    Will we be able to apply denoise, dering and deblock filters on sources ?
  4. Master of my domain thoughton's Avatar
    England
    Major you rock
    Tim Houghton
    WebsitePhotography
  5. Originally Posted by G Rom
    Major,
    It uses ffmpeg. Probably I'll also add the same with mencoder later.
  6. Member G Rom's Avatar
    Aug 2005
    Montpellier, France
    All right,
  7. I am glad to hear that the next update is so close. Thanks again for all your hard work.
    I use ffmpegx mostly for PSP conversion so I am looking forward to it supporting h.264 for the PSP. You may already be aware of all this, but I thought I would mention it anyway. PSP Video 9 and 3GP Converter both use ffmpeg for Windows to convert to PSP's AVC format. I don't know what differences there are between the ffmpeg encoders for the two platforms but I was hoping that if the Windows version can do it, so can the Mac although I realize this may be a muxing issue and not an encoding issue. The PSP will not recognize standard h.264 files. It requires the "Sony atom" in the header simliar to the widescreen trick.
    Hopefully this helps, if not, oh, well.
  8. Indeed PSP H.264 has a non-standard muxing profile, but this will be worked out.
  9. Releasing of 0.0.9t should happen today or tomorrow.
  10. Member G Rom's Avatar
    Aug 2005
    Montpellier, France
    major,
    you are my saver !
  11. hi,
    where to get update. did I miss it?
    thx
  12. It will be announced here as soon as it is out. I'm just working on it and sleeping, nothing else.
    Aug 2005
    North America
    thanks. is there any possibility of a little more info on it?
