After processing, I'm getting a faint sound of pops and clicks in the audio... very subtle, almost like the quiet background noise of a vinyl LP. It's definately not in the original capture.
Anyone have any clues?
Thanks!
mojo
What's the audio sample frequency of your input file? If it's not 44.1Khz, that will often cause problems such as you are experiencing...
Al -
and plus i recommend that you use tooLAME and SSRC to process you audio beacuase this will lead to better qaulity audio
you can use SSRC and tooLAME as an external tool just go to
Option->Enviormental Settings->External Tool and click layer 2 and search for tooLame.exe then click smapleing fruquancy convertor and search for SSRC.exe
Mojo,
Convert your audiostream to 44100 in virtualdub, and encode
I had the same problem. Toolame won't solve your problem.
Virtualdub will.
clicks and pops in very old VHS tape
By snafubaby in forum Capturing and VCRReplies: 0Last Post: 27th Sep 2009, 03:55 -
virtual dub filters for clicks and pops
By snafubaby in forum AudioReplies: 2Last Post: 11th May 2008, 21:29 -
pops or clicks in wav file
By johnsees in forum AudioReplies: 7Last Post: 30th Jan 2008, 05:08 -
Pops, Clicks when ripping DVD
By coyotewrw in forum DVD RippingReplies: 1Last Post: 14th Nov 2007, 18:57 -
MP3>ac3 pops and clicks
By joesphroth in forum Authoring (DVD)Replies: 0Last Post: 6th May 2007, 15:18
