    May 2004
    Spring Hill, Florida
    I have been using windv to capture from my advc-55.
    Works pretty good. However I found out unexpectedly that large vhs tapes cuz it to break into two files. (RobRoy 2hrs 39 mins) I set the limit to 1000000.
    I could not find if theres a way to make it unlimited or if there was a reason I would not want it all as one file. ?
    mark
  2. Member daamon's Avatar
    Melbourne, Oz
    Hi freebird1963,
    I presume you're referring to "the limit" as the max number of frames. A max of 1,000,000 for PAL (Hint: Complete your location details), would mean around 11 hours, slightly less for NTSC.
    What have you got the "Discontinuity threshold" and "Every Nth frame" set as? If they're not set to 1, try that.
    Also, how big are the files? Is one of them around 4Gb? I ask because a FAT32 file system has a limit of 4Gb for file sizes. If it's FAT32, change it to NTFS. But, as you're running Win2K, this is unlikely.
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
    May 2004
    windv is setup as follows.
    NTSC by the way.
    discontinuity threshold 0
    max Avi size [frames] 1000000
    Every N-th Frame 1
    type 2 avi (vid+auds) is checked.
    Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.
  4. Member daamon's Avatar
    Melbourne, Oz
    Carpe diem.
