Is a good way to compare 2 identical video files sound sync is to drag one in vdub.
look at say a door slam (frame: 40035)
delete all other frames before and after it until im only left with like..2 frames and save it and then load the other version (from say a DVD-R)
go to frame 40035 (where the doors slamming) and save that and if on the second audio its the door slamming but with either no audio or audio but a second later is that a good way of findinbg if sounds out of sync?
But if the sound and video is exactly the same on both files it means both videos have the same sync right?
Results 1 to 1 of 1
Video in Virtual dub out of sync
By lituvis in forum Video ConversionReplies: 0Last Post: 7th Mar 2012, 10:56 -
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 14:48 -
Virtual Dub Audio Not In Sync
By RKelly in forum EditingReplies: 2Last Post: 28th May 2008, 20:45 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 16:36 -
Audio out of sync after running file thru virtual dub
By AORMan in forum Video ConversionReplies: 3Last Post: 2nd Oct 2007, 14:35
