How can we author a dvd with the dvd-lab pro that can start playing two subtitles that we may have done for it, while it starts, at the same time? I did try to mark/check the option "Set this Subtitle always On by default" at the dvd-lab pro, at both of them, but I think that while we mark/check one, the other is unmarked/unchecked.
Closed Thread
dvd spec does not allow you to play 2 subtitle streams at once.
it will only allow you to play at once.
1 video stream (angle)
1 audio stream (language)
1 subpicture (& highlight buttons)
i hear the new HD specs allow for multi stream playback for some picture in picture effects..Some people are only alive because it may be illegal to kill them
playing just subtitles
By Alexandru in forum Software PlayingReplies: 4Last Post: 30th Mar 2012, 10:05 -
Playing PGS subtitles with MPC.
By doctorm in forum SubtitleReplies: 2Last Post: 28th Jan 2012, 13:25 -
Which software that can display 2 different subtitles while playing movie?
By JackyWang in forum Software PlayingReplies: 2Last Post: 29th May 2011, 08:43 -
Problem playing subtitles on some movies
By acinider in forum SubtitleReplies: 7Last Post: 29th Jan 2009, 18:06 -
No subtitles when playing a .MKV file in MPC HC
By THX-UltraII in forum SubtitleReplies: 5Last Post: 21st Aug 2008, 08:08
