All the things I have used so far VDub and TMPGE convert AVI -> MPEG.
Now I'm working with CCE and doing a 3 pass on my files. but It only saves files as .mpv & .mpa
How do I convert the two file types to an MPEG2 video I can burn using (what I normally use) DVD Movie Maker?
Thanks,
Troy
Truman,
Thanks.
Is TMPGE "okay" as far as software is concerned for Multiplexing?
Thanks,
Troy -
You mentioned DVD. TMPG can not multiplex to a dvd compliant MPEG, but bbMPEG.
For SVCD bbMPEG might be better.
For (X)VCD you can use TMPG as well. -
I mentioned DVD (as in ULEAD DVD Movie Maker).
Final output is to SVCD (XSVD) of a TV show.
Thanks for the help Truman.
Troy
Only DVD_NTSC folder with MPEG2 file inside after converting
By big_b0i in forum Newbie / General discussionsReplies: 4Last Post: 30th Jun 2011, 09:23 -
How does one process mpa and mpv files?
By mysts in forum Authoring (DVD)Replies: 2Last Post: 11th May 2011, 14:30 -
How to convet mpv file to m2v file format?
By Bonie81 in forum Newbie / General discussionsReplies: 4Last Post: 28th Oct 2010, 07:17 -
Why does XVID avi file balloon in size when converting to mpeg2 or dvd?
By im2020 in forum Video ConversionReplies: 3Last Post: 11th Aug 2010, 13:30 -
MPV and MPA out of sync with Media Player Classic
By Talayero in forum Newbie / General discussionsReplies: 2Last Post: 13th Mar 2009, 09:34
