Hey all
I have an AVI file thats about 1gb, which I want to convert to VCD. Its about an 1 hour and 20 minutes long. I want it to be on one CD. What program can I use???? Thanks
A bit of searching will reveal that...
TMPGEnc is free for encoding AVI to MEPG1 - the MPEGs used for VCDs. There are other encoders.
A good VCD authoring tool is VCDEasy, though there are others.
As for whether 1h20m will fit on a CD - I don't know. Check it out on the VideoHelp Bitrate Calculator. You may need more than one CD, or create a non-compliant VCD.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
VCDs are constrained to a bitrate of 1,150kbps - meaning that if you try to make the file smaller by using a lower bitrate it won't be compliant and your player may not play it.
The other alternatives are to shorten the footage so it fits on one CD (not an option, I'm assuming) or, spread the footage over 2 or more CDs.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
http://members.dodo.net.au/~TMPGEnc1CD.htm might help. It's specifically designed for one disc XVCDs, although 80 minutes of VCD should fit on a 700MB CD. The secret with Nero is to untick the "Create standard compliant VCD" tickbox:
If in doubt, Google it.
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 19:28 -
How to convert an .avi or .mkv or .mp4 file to mpgav for burning to a VCD
By jasoothai in forum Authoring (VCD/SVCD)Replies: 8Last Post: 29th Oct 2011, 20:35 -
One hour, 37min AVI file that I want to turn into a VCD
By penang in forum Newbie / General discussionsReplies: 23Last Post: 17th Feb 2011, 11:11 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 08:36 -
Burn .avi file to VCD while still retaining subtitles
By Holymoly in forum Video ConversionReplies: 1Last Post: 12th Dec 2007, 22:30
