I have a dvd of a band's gig that a friend filmed and the auido is only only on the left speaker. Is there a semi simple to add audio to the right side?
extract audio track, if ac3, extract to wav, make wav dual mono, convert back to ac3 (if it was ac3 to begin with), reauthor.. if there is enough room on the disc to support the audio & wav, then you dont need to convert to ac3.
Not simple
Well, relatively not that bad. You would have to extract the audio, run it through a audio editor and clone the one channel to the other, then mux it back into the video and reauthor.
This is something that needs to be checked before the video is authored in the first place. If you have the original video with stereo, it would be better to use that as otherwise with the above method, you would only have dual mono. Either way, it would probably be easiest to reauthor.
How to restore audio on the right speaker on a video file
By Tintin11 in forum RestorationReplies: 8Last Post: 13th Nov 2010, 07:30 -
Edited sound jumps from speaker to speaker
By len hend in forum AudioReplies: 3Last Post: 23rd Jul 2010, 05:49 -
Audio out of only one speaker - ULead/EasyCap
By gmania in forum AudioReplies: 0Last Post: 16th Oct 2009, 21:03 -
How fix mp3 with audio comming out of a single speaker ?
By hiavi in forum AudioReplies: 2Last Post: 17th Sep 2009, 22:28 -
Audio coming from center speaker help
By faramith in forum AudioReplies: 6Last Post: 19th May 2007, 22:15
