thanks for for the continued support with this awesome softwear.
recently, ffmpefx has been playing up...when i finish encoding an avi to dvd ffmpeg file...it has been producing a video_ts and an audio_ts folder. however, in the video folder there are only two files ie: (VTS_01_1.VOB) instead of the usual 6 or 7 files. this means i cant burn the dvd because it cant be read in apple.
furthermore, if i put in multiple files to encode it`ll `sometimes` encode the first one but then not produce anything for the others (maybe just an mpv file - even though the process window shows that it has finished. the info button states that it couldnt open the file...but if i try it again it will encode the file - but with the problems mentioned in the first paragraph.
sorry if this is confusing to read - its confusing me too!
thanks for any help
Are you sure that there are no spaces and special characters in your paths? You may also try to email me to major4@mac.com your complete terminal output.
PAL/NTSC DVD/VCR combo that will play DVD+R's w/o A/V synch problems?
By wetcamelfood in forum DVD & Blu-ray PlayersReplies: 12Last Post: 12th Jan 2010, 16:25 -
DVD-Lab Pro: DVD-R DL burning problems
By jonghyunchung in forum Authoring (DVD)Replies: 3Last Post: 14th Dec 2009, 07:57 -
DVD Editing from Panasonic VDR-D220 Mini DVD and interlacing problems
By gbnz in forum EditingReplies: 3Last Post: 15th Oct 2008, 14:34 -
Sync problems while authoring a DVD with DVD Flick
By TioSolid in forum Video ConversionReplies: 1Last Post: 16th Aug 2008, 13:21 -
Help with audio problems on dvd-lab pro and / or subtitles on a dvd
By Jack the Ripper in forum Newbie / General discussionsReplies: 12Last Post: 7th Dec 2007, 18:00
