i just wanna know what is the best dvd encoder that can encode to svcd or vcd? or converter?
There is no best - the best is the one that works for you.
I use TMPGEnc Plus, but CCE, Mainconcept and Procoder are some of the more common payware ones, while QuEnc seems to be a good free encoder.
If you're talking about going straight from DVD to VCD/SVCD then my preference is to use EazyVCD. It don't get any easier than thatIf in doubt, Google it. -
There is no 'best'. There is only what is 'best' for you.
Define what you want to do, how complex you want things to be, how much you are willing to spend and how much effort you are willing to put into this and maybe someone can offer a few suggestions. But even so, there is no 'best'. If there was, all the others would be out of business!Want my help? Ask here! (not via PM!)
The best is TMPGENC.
Now quit asking questions and get to work!!!
Really, that's the best way to learn.
The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is TMPGENC.The best is [removeme]TMPGENC[removeme].The best is [removeme]TMPGENC[removeme].The best is [removeme]TMPGENC[removeme].The best is [removeme]TMPGENC[removeme].The best is [removeme]TMPGENC[removeme].The best is [removeme]TMPGENC[removeme].The best is [removeme]TMPGENC[removeme].The best is [removeme]TMPGENC[removeme].The best is [removeme]TMPGENC[removeme].The best is [removeme]TMPGENC[removeme].The best is [removeme]TMPGENC[removeme].The best is [removeme]TMPGENC[removeme].The best is [removeme]TMPGENC[removeme].The best is [removeme]TMPGENC[removeme].The best is [removeme]TMPGENC[removeme].The best is [removeme]TMPGENC[removeme].The best is [removeme]TMPGENC[removeme].The best is [removeme]TMPGENC[removeme].The best is [removeme]TMPGENC[removeme].The best is [removeme]TMPGENC[removeme].The best is [removeme]TMPGENC[removeme].The best is [removeme]TMPGENC[removeme].The best is [removeme]TMPGENC[removeme].The best is [removeme]TMPGENC[removeme].The best is [removeme]TMPGENC[removeme].The best is [removeme]TMPGENC[removeme].The best is [removeme]TMPGENC[removeme].The best is [removeme]TMPGENC[removeme].The best is [removeme]TMPGENC[removeme].The best is [removeme]TMPGENC[removeme].The best is [removeme]TMPGENC[removeme].The best is [removeme]TMPGENC[removeme].The best is [removeme]TMPGENC[removeme].The best is [removeme]TMPGENC[removeme].The best is [removeme]TMPGENC[removeme].The best is [removeme]TMPGENC[removeme].The best is [removeme]TMPGENC[removeme]. -
Hmmm, I'm with Jim and Smurfie....there is no best encoder....they all do what they are designed to do......ie encoding MPEG2...to say TMPGenc is the best is stupid....teir interfaces/speed/nuances might well be different..but will one pocket calulator add 2+2 to make anything other than 4?.....and as Jim says I've also (and I dare say Smurfie) used/tried most of the common encoders and the end result is......well, 4....which is what it should be, no?
But.....TMPG for VCD's/mpeg1 is FREE...No2: We want Information.
No6: You wont get it!
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 18:14 -
How it possible Video: X264 encoder with Matroska encoder extension?
By flash_os in forum Newbie / General discussionsReplies: 1Last Post: 11th Feb 2012, 09:13 -
Your Best Video Encoder/Re-encoder???
By iqbal88 in forum DVD RippingReplies: 2Last Post: 15th Aug 2011, 08:09 -
how to tell what encoder was used for a dvd's video?
By Toastie in forum EditingReplies: 2Last Post: 25th Mar 2011, 20:45 -
Error with Nero AAC encoder in XVID4PSP - "Could not open AAC encoder&
By TheViking in forum Video ConversionReplies: 2Last Post: 5th Nov 2009, 01:41
