Hi, i'm new here so i'm not sure if this is in the right area. Sorry if it isn't.
Anywho, i recently purchased the DVD authoring program DVDComposer. The program works perfect and I've had hardly any difficulty using the main features. However, my problem comes when I attempt to 'build' the DVD...i constantly get this following error message....
Error M027: Unable to write a video pack to program file
Does anyone here know what this message means and if there's any way around it? Any help at all would be greatly appreciated....
Cheers!
Xian Tianhan.
1) make sure you have a LOT of free space where you are building the disc.. you will need 2x the amount of space the disc requires (I suggest at least 10gb free for a 4.3gb disc).
2) make sure you are using 1.0.3
3) if you are using Womble to edit your video, make SURE you are using the latest version or grab a copy of ReStream and pass they M2V file thru it and have it 'remove end sequnce codes' (earlier versions of MVW would leave an extra end code in there an confuse the muxer.
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 20:18 -
Help on Video Error. Thanks.
By seymoria in forum EditingReplies: 2Last Post: 5th Apr 2009, 11:40 -
video compression error
By Russo in forum Newbie / General discussionsReplies: 5Last Post: 21st Nov 2007, 15:23 -
DVDComposer >> regonal settiing...
By 2Weights in forum Authoring (DVD)Replies: 8Last Post: 7th Nov 2007, 06:44 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41
