I didn't find this tip in the forum or "how to" guides, so I figured I'd better share it.
TIP: Set VirtualDub's "Chunk Size" to 4 MB or more.
By adjusting VirtualDub's Disk I/O settings, I have quadrupled my computer's capture bandwidth. Under the "Capture" menu, I opened the "Disk I/O..." dialog box and raised the Chunk Size to 4 MB. Instantly, my Bt878 could effortlessly capture at 720x480, with bandwidth to spare.
So my advice is, make the "chunk size" as big as conveniently possible. (There's probably a point of diminishing returns around 6 MB.) The number of "chunks in buffer" doesn't seem to be quite as critical. It works okay with just 2, but raising it to 4 seemed to reduce the risk of dropped frames during very long captures.
When the chunk size is very large like this, the hard drive becomes relatively placid while capturing; it writes in small bursts once or twice a second.
As an experiment, I started pushing the limits last night, configuring my card for 720x480 @ 30 fps, 24-bit RGB uncompressed. (These are wasteful settings just for testing.) That's over 20 MB/sec, but it still dropped only one frame in the first 30 seconds. By contrast, my system barely handled 4.5 MB/sec with the default disk settings. And yes, I did verify that the captured video was intact.
This trick might not yield such a dramatic improvement for everyone, but give it a try and report your results (or failures).
I was inspired to try this after reading in the "Hardware Bible" that IBM hard drives omit address marks and sector gaps to save space. I wondered if this meant cylinders had to be written all-at-once, rather than a sector-at-once. That's probably wrong, but I decided to test my IBM drive with much bigger chunk sizes, and that yielded a four-fold bandwidth increase! A 5400 RPM Western Digital drive showed a similar improvement.
Any comments?
-TacoSalad
Does anyone know if setting my lite raid on my K7T Turbo-R
to the(video editing)setting instead of(desktop)would help
for dropped frames?Do I need to fdisk it that way after I
change it? -
Tacosalad,
There is a little blurb about chunk-sizes in Lukes Video Guide http://www.geocities.com/lukesvideo/index.html, under the Hi-Res VDub Capture section. He recommends 2mb x 4, but you can experiment to see what works best.
Change length of an AVI. Reduce/Increase Frame Length
By Buzwinkle in forum Authoring (DVD)Replies: 4Last Post: 10th Aug 2011, 09:08 -
Capture Card - file Sizes and how to reduce?
By schmidtrg in forum Capturing and VCRReplies: 1Last Post: 12th Jun 2008, 00:12 -
1080p over LAN bandwidth?
By W_Eagle in forum DVB / IPTVReplies: 6Last Post: 28th Jan 2008, 09:11 -
Does quoting someone else's post use bandwidth?
By moviebuff2 in forum ComputerReplies: 5Last Post: 15th Jan 2008, 21:16 -
The Best Capture Codec to reduce artifacts is???
By maxtrack in forum Capturing and VCRReplies: 5Last Post: 27th Jul 2007, 16:47
