I have a show captured from my Satellite Dish on my JVC DRM10 that needs the video adjusted before I edit and author to DVD.
The recorder's captures normally look great so I'm pretty sure it came off the Dish this way. Its washed out looking and needs the saturation and color adjusted.
I'm using Womble for editing and TMPGEnc DVD author before I burn to DVD. Is there an easy way to adjust saturation and color on this capture? If it requires re-encoding I'd like to do that with minimal loss in quality. The video was recorded at the 90 minute setting so has plenty of bandwidth.
Thanks.
whats up off?
The only way to fix this is to apply filter and re-encode. You can use TMPGEnc which has built in filters to do this. Just re-encode at the same average bitrate that the DVD recorder used, which is somewhere around 6 to 6.5 Mbps, which is the approximation of the 90-minute record mode.
To do this burn the recording to a RW disk in VR mode. Then just copy the contents on the RW disk to your computer hard drive. If there are segments i the video file that you do not want, just edit in Womble and save as new file. Now it gets tricky.
You will need:
TMPGEnc
VirtualDubMOD or VirtualDub MPEG2 (both free)
TMPGEnc does not accept *.mpg files, so you have to convert the file.
Open your file in virtualdub, then click on FILE -----> Frameserve------- type in a name (ex.: movie.vdr.avi). Also, as an option you can use the Virtualdub filters to add the color you want. Actually I would recommend it.
DO NOT SHUT DOWN virtualdub!!!!!! virtualdub is creating a dummy file to fool the encoder to think it is an *.avi, so virtualdub should remain running.
Open TMPGEnc and open up "movie.vdr.avi". Apply filters color filters (if necessary) and encode to new file. For more detail on this process, see the tutorials on each application on this site.
Converting a color video to black and white apart from one color. Possible?
By SteveLock in forum EditingReplies: 7Last Post: 23rd Feb 2009, 08:04 -
[color=blue]video oediting software for ASUS Eee PC (white ones)[/color]
By helpmepls in forum Newbie / General discussionsReplies: 1Last Post: 6th Feb 2009, 07:53 -
How to adjust Color/Brightness/Contrast/Etc in firewire camera?!?! PLEASE..
By vegassteven in forum Newbie / General discussionsReplies: 7Last Post: 14th Dec 2008, 06:54 -
Software to adjust Color, Tint, Contrast.............
By richards2222 in forum Authoring (DVD)Replies: 3Last Post: 8th Apr 2008, 04:57 -
Can a DVD recorder change a DVD color system?
By coody in forum DVD & Blu-ray RecordersReplies: 6Last Post: 14th Dec 2007, 12:16
