as above. If can, how do i do it?
Try this. https://www.videohelp.com/guides.php?link=662.
You can also use EO Video.
If you are just opening it, make sure you have a RM codec installed. You can use Real Alternative Player. -
i have real player installed and not the real alternative codecs. Can this work as well?
Yes, it should. You just need a RM codec installed. I haven't tried this as I rarely use RM. If the method in the 'Guide' won't work, try EO. RMVB can be difficult at times.
VirtualDub will not open Lagarith file
By StrobeLightEpileptic in forum EditingReplies: 14Last Post: 24th Jun 2010, 00:09 -
How to open a small flv file in virtualdub?
By Wizard81 in forum EditingReplies: 4Last Post: 20th Nov 2009, 12:14 -
TMPgence xpress 4 can't open rmvb file
By sychern in forum Video ConversionReplies: 0Last Post: 10th Jul 2009, 20:55 -
RMVB to DIVX (Cannot open file)
By leogeo in forum Video ConversionReplies: 5Last Post: 24th Nov 2008, 21:14 -
VirtualDubMod 1.5.10 cannot open rmvb file
By pchan in forum Video ConversionReplies: 2Last Post: 14th Sep 2007, 09:17
