Results 1 to 18 of 18
  1. Member golfnut's Avatar
    Sep 2003
    Please give me your recommendations. I am looking for something simple and easy to use but good quality and something that will convert 5.1 and/or DTS audio as well. Thank you very much for your help.
    Thank You,
    GolfNut
    USA
    Not sure about 5.1 Audio, but try VSO DivxToDVD. Very easy.
  3. Member golfnut's Avatar
    Sep 2003
    Thanks Redbudz but I would have thought that out of 117 views I would have a few more folks respond, I guess not.
    Thank You,
    GolfNut
    Nov 2002
    I would think that would be a blessing. I hate getting 117 different suggestions and then have to download and test them all.
    I haven't tried Gui4ffmpeg but VSO DivXToDVD is as simple as it gets. You might still be able to find the free version somewhere on the internet but I'm not sure if it will convert 5:1 AC3 or DTS. The new version will but it costs $29.99 to buy.
    http://www.vso-software.fr/divxtodvd/divxtodvd2.htm
  5. Member golfnut's Avatar
    Sep 2003
    Tried Guiffrmpeg but I am trying to convert from DIVX to DVD, looks like this software converts from DVD to DIVX, just the opposite of what I am looking for? The freeware version of DIVXtoDVD does not convert AC3 so that is out unfortunately. Thank you for your responses and info but I am still looking if anyone else has any suggetions, thanks again to all.
    Thank You,
    GolfNut
  6. Mod Neophyte redwudz's Avatar
    USA
    Maybe TheFilmMachine? 5.1 is not so common on XVID or DIVX vids as most seem to use MP3 audio. TFM mentions AC3, but I didn't notice if 5.1 was available. Most programs that convert audio from MP3 go with AC3 2 channel, at least in the All-in-Ones.
    You might have to do it the 'hard' way to keep your 5.1.
  7. Member golfnut's Avatar
    Sep 2003
    Redbudz I think you are right. Thanks again for the info and staying in touch. Have a great evening.
    Thank You,
    GolfNut
  8. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    EDIT:
    If in doubt, Google it.
  9. Member golfnut's Avatar
    Sep 2003
    Jimmalenko thank you for that link and info.
    Thank You,
    GolfNut
  10. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Uhhhh ..... what link ?
  11. Member golfnut's Avatar
    Sep 2003
    "MY GUIDES"
    Thank You,
    GolfNut
  12. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Oh
    That's in my signature
    Apr 2005
    Germany
    Gui4ffmpeg converts Divx/Xvid to DVD too.
    There is a guide to convert Divx/Xvid to DVD
    https://www.videohelp.com/forum/viewtopic.php?p=1345948#1345948
    The home of the sun - http://www.blueview.de.vu
  14. Video Restorer lordsmurf's Avatar
    Originally Posted by jimmalenko
    Oh
    Good job.
  15. Member golfnut's Avatar
    Sep 2003
    gui4ffmpeg first of all thank you for this software and the guide on how to use it. I have used it to convert my divx file to DVD. In so doing it coverted my divx file to mpeg. I am trying to burn the mpeg file it created to a DVDR but I do not know how to do this. Can you possibly tell me what software I need. I have tried burning the DVDR with CloneDVD but I get error message saying file can not be found. I guess this is because it is an mpeg file?? Please help if you can. Thanks again.
    Thank You,
    GolfNut
    Apr 2005
    Germany
    With gui4ffmpeg the mpeg file will be generated. Now the DVD has to authored and burned.
    This is my procedure:
    Authoring
    Freeware: Gui for DVDauthor
    Website: https://www.videohelp.com/tools?tool=GUI_for_dvdauthor
    Guide: https://www.videohelp.com/~gfd/GUI_DVDauthor_eng_07.htm
    Burning
    Gui for DVDauthor also contains a burning feature, but i never tried this.
    I use Nero.
    Good luck!
  17. Member golfnut's Avatar
    Sep 2003
    gui4ffmpeg, GOT IT! Thanks a million for your help.
    Thank You,
    GolfNut
